AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Copy problems
2 REPLIES 2
tchop
188 Views, 2 Replies
Copy problems
Using Autodesk Building Systems I have a few VAV boxes that I would like to be able to just copy around instead of using the Insert Mechanical Equipment tab. I can copy ducts and text and such but when I try to copy a VAV box I get the following prompt. As far as I can tell I havent changed any snap settings. I even try to type in a distance such as 5' and still the block doesnt go where I want it to.
Select objects:
Specify base point or displacement, or [Multiple]: Specify second point of
displacement or
Thanks for any help.
2 REPLIES 2
in reply to: tchop
Unless I'm mistaking your issue, the prompt is asking you to enter a
start point, (left click your mouse button) to a finish point, (left
click your mouse button). Similar to moving any other autocad entity.
> Select objects:
> point of
> displacement or
tchop
in reply to: tchop
Thats not the problem. The problem is...if I left click the mouse as my start point...then I move the mouse up the screen to left click my detsination point....the object doesnt go where it want it to. It puts a copy of the block right on top of itself no matter where I click on the screen. I cant mirror or move it either. It's a problem with the block itself I have found.
”Boost
