Unless I'm mistaking your issue, the prompt is asking you to enter a
start point, (left click your mouse button) to a finish point, (left
click your mouse button). Similar to moving any other autocad entity.
tchop wrote:
> Using Autodesk Building Systems I have a few VAV boxes that I would
> like to be able to just copy around instead of using the Insert
> Mechanical Equipment tab. I can copy ducts and text and such but when
> I try to copy a VAV box I get the following prompt. As far as I can
> tell I havent changed any snap settings. I even try to type in a
> distance such as 5' and still the block doesnt go where I want it to.
> Select objects:
> Specify base point or displacement, or [Multiple]: Specify second
> point of
> displacement or
