AutoCAD MEP General
New Member
Message 1 of 3 (556 Views)
Copper Piping & Fittings in AutoCad MEP 2011
556 Views, 2 Replies
12-09-2012 06:52 AM
OK I need some help here.  I am working on a large project.  I have to layout all of the plumbing in 3D using AutoCad MEP 2011.  My problem is the Copper piping.  Which type should I use that would give me the largest fittings library.  I will need alot of sizes between 1/2" - 6" copper fittings.  And where do I find the valves?
Please help !!!!
Product Support
Message 2 of 3 (518 Views)
Re: Copper Piping & Fittings in AutoCad MEP 2011
12-14-2012 02:17 PM in reply to: Zplumbing1414
"Plumbing Lines" in AutoCAD MEP are 2D schematic lines.  So I'll assume you want to draw 3D "Pipes" instead that represent Plumbing with copper fittings.  They are in there, it's just one copper fitting catalog and Routing Preference.
If you do not see the copper fittings needed, you can always make them using Content Builder.  Here are some videos I made to teach how to use Content Builder.  Content Builder makes both MvParts and Fittings that can be used for Duct, Pipe, Conduit or Cable Tray.  The concept is the same, so what you learn in the videos will apply across the board.
Here's a link on www.YouTube.com/SupportAcadMEP:
http://www.youtube.com/playlist?list=PLCBDF999706C3EE65
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Senior Support Specialist
Product Support
Autodesk, Inc.
Product Support
Message 3 of 3 (478 Views)
12-20-2012 12:12 PM in reply to: Zplumbing1414
Wanted to follow up and see if the info helped?
Joshua
Joshua Benoist, PE
Product Support
Autodesk, Inc.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
