AutoCAD MEP General
Active Member
dacamp
Message 1 of 5 (368 Views)
Content Builder - problem adding geometry
368 Views, 4 Replies
01-07-2010 01:03 PM
I'm trying to draw a custom pipe fitting in the Content Builder and it won't let me draw lines (when adding geometry) if they are too close to existing points (the nearby points will highlight). If I move a bit further away I can draw the line, but then it's too long. The line I'm trying to draw is an inch long, nothing very small. Is there a setting that controls this?
Employee
gregg.stanley
Message 2 of 5 (368 Views)
Re: Content Builder - problem adding geometry
01-11-2010 06:48 PM in reply to: dacamp
In content builder scale does not matter since you need to use a dimension or constraint to define the true length of the line. For drawing you can change the annotation scale and Regen to make all the items smaller.
Gregg Stanley [Autodesk]
Gregg Stanley
QA Analyst
AEC
Distinguished Contributor
Schmit01
Message 3 of 5 (368 Views)
01-12-2010 03:47 AM in reply to: dacamp
You could also just draw the line longer than what is required then dimension it and then set it to the correct size.
Ryan Smit
Active Member
dacamp
Message 4 of 5 (368 Views)
01-12-2010 04:17 PM in reply to: dacamp
OK, thanks. I see what you both mean.
Member
t.vanskyock
Message 5 of 5 (196 Views)
08-21-2012 06:52 AM in reply to: Schmit01
How do I dimension it to the right size??? Please help
You are not logged in.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
