AutoCAD MEP General
Member
Message 1 of 4 (105 Views)
Changing Styles and Width factor for Light and Diffuser Tags
105 Views, 3 Replies
08-12-2003 12:29 AM
I want light and difffuser tags to use style REGT which uses FONT Romansp.shx with a width factor of 0.8. Is there an easy way to do this without exploding the block and editing the attribute text. Changing the Standard dim style to REGT only changes out the FONT and the width is not affected.
Mark
*[Autodesk], jason martin
Message 2 of 4 (105 Views)
Re: Changing Styles and Width factor for Light and Diffuser Tags
08-13-2003 12:55 AM in reply to: Mark_Leaf
Hi Mark -
The view blocks inside the tags work in the same way as a standard AutoCAD
block.
The width factor of the attributes are applied to each instance of the
blocks rather than the block definitions.
If you always wanted the blocks to show this way you should edit the content
drawings, so that they come in with a default width factor of .8.
jason
"Mark_Leaf" wrote in message
news:f180702.-1@WebX.maYIadrTaRb...
affected.
> Mark
Member
Message 3 of 4 (105 Views)
Re:
08-13-2003 02:48 AM in reply to: Mark_Leaf
Jason, I did a search for the content drawing and it was not located.
Member
Message 4 of 4 (105 Views)
Re:
08-13-2003 04:42 AM in reply to: Mark_Leaf
Jason,
Thank you for your time, I figured it out.
Mark
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
