AutoCAD MEP General
davebillion
Message 1 of 3 (314 Views)
Can't get Parametric MvPart to Resize.
314 Views, 2 Replies
12-20-2012 09:03 AM
Greetings,
I created a Surface Mount Ceiling Mount Diffuser with a table of available neck sizes.
Regardless of the size selected, only the 12x6 is inserted, with the 12x6 connector.  If I do a MvPart Modify, I can select any size (6x6 all the way trough 24x4), but the part does not change and the connector remains 12x6.
I've made parametric duct fittings and parametric pipe fittings in the past, with no troubles that a little debugging couldn't fix.  This time, I'm stumped.
I've attached all appropriate files for review.  Can someone provide some insight?
Platform is AutoCAD MEP 2011.
Thank you,
Dave
Keith.Brown
Message 2 of 3 (270 Views)
Re: Can't get Parametric MvPart to Resize.
12-31-2012 08:59 AM in reply to: davebillion
You need to remove LenA1 and LenA2.  They are redundant and not needed.  I went into your part size name and replaced LenA1 and LenA2 with RW1 and RW2 and then deleted LenA1 and LenA2 and everything worked perfectly.  I believe the reason why it wasnt working is that you had two different lengths trying to control the same points of geometry.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
davebillion
Message 3 of 3 (265 Views)
12-31-2012 12:15 PM in reply to: davebillion
<Facepalm>
Rookie mistake.  Thanks.
You are not logged in.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
