AutoCAD MEP General
Active Contributor
shawnbassplayer
Message 1 of 4 (552 Views)
Can't edit fittings within the Properties Dialog box
552 Views, 3 Replies
11-06-2012 10:53 AM
I'm sure there's a toggle somewhere for this.  But I can't seem to edit fittings within the properties box.  If I have a transition that's 30 degrees, I can select the angle and make it 15, but it doesn't change or do anything.  If I actually click on the part shown above, I can find the angle and change it there... just not in the first properties box.  Anyone come across this?
Product Support
Joshua.Benoist
Message 2 of 4 (523 Views)
Re: Can't edit fittings within the Properties Dialog box
11-09-2012 09:53 AM in reply to: shawnbassplayer
Is there a duct segment (or pipe) connected at either end of the elbow?
Joshua
Joshua Benoist, PE
Senior Support Specialist
Product Support
Product Support
Joshua.Benoist
Message 3 of 4 (500 Views)
11-12-2012 12:12 PM in reply to: shawnbassplayer
Wanted to follow up.
Joshua
Joshua Benoist, PE
Product Support
Active Contributor
shawnbassplayer
Message 4 of 4 (270 Views)
04-12-2013 10:24 AM in reply to: Joshua.Benoist
I forgot about this question, but now that I'm doing some more BIM jobs, it's come back up.  Yes, the problem seems to be when I have duct connected to the fitting.  I can easily modify an elbow or transition if it's alone within the properties dialog box.  But if the elbow or transition has ductwork attached, it won't change.
You are not logged in.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
