AutoCAD MEP General
PanzerRanger
Message 1 of 2 (405 Views)
Cal and Plt publishing
405 Views, 1 Replies
11-08-2012 02:48 AM
Is there a way to publish several layout in several diffrent drawings to plt and cal files in one printing session?
I.e. for pdf, select publish choose drawings to be part of sheet and select publish, program creates all pdf
PanzerRanger
Message 2 of 2 (192 Views)
Re: Cal and Plt publishing
06-10-2013 02:33 AM in reply to: PanzerRanger
Yes, if you the PUBLISH command. Our firm uses a dwg file with variations of diffrent plotsettings configured in it. When running the publish command we select, publish to, plotter named in page setup. Under Page setup we import the settings from the dwg file and use the plotmethod we want and  just publish away.
You are not logged in.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
