AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
CadDuct Object Enabler Problem
10 REPLIES 10
Message 1 of 11
TravelTheWorld
10550 Views, 10 Replies
I have installed MEP 2010 on my computer, and I haven't been able to view drawings drawn with CadDuct. I have installed Autocad Object Enabler and CADmep+ & CADduct Object Enabler on my computer, but I still won't be able to view them. When I opened a CadDuct drawing with my MEP 2010, all I could see was some blocks and texts, not duct work.
Has any of you encountered this problem? If so, what was it you did to resolve this problem?
Thank you,
10 REPLIES 10
Message 2 of 11
I had the same problem so I exported the CadDuct drawing to AutoCAD 2007 format and it worked.
Message 3 of 11
in reply to: TravelTheWorld
I had the same problem in MEP 2009 and when I loaded the mapcadduct.dbx file
manuallly using application load, it worked.
"jasonpark0911" wrote in message news:6333761@discussion.autodesk.com...
Thank you,
Message 4 of 11
Anyone have a 2013 version for this enabler yet.. I am receiving drawings from subs and cannot get their items to show up... AutoCAD says it cannot load the .dbx file...  I am not sure if it is old or not compadible to AutoDesk 2013 versions
Message 5 of 11
Here are the details for the CADmep object enablers:
Fabrication CADmep 2013 object enabler (for 2013 products only)
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-fabrication-...
CADmep legacy enabler for AutoCAD 2009-2012 (as *Mike mentions, this version requires manual registration with AutoCAD)
http://knowledge.autodesk.com/support/fabrication-products/downloads/caas/downloads/content/legacy-v...
Hope this helps.
Nick
Nicholas Hyland
Message 6 of 11
rmc1111
2014 NAVISWORK
UPGRADED FROM AUTOCAD 2013 TO 2014 ALSO THE SAME WITH NAVISWORK AND I ALSO INSTALLED AUTODESK FABRICATION CADMEP 2014 OBJECT ENABLER I  HAVE SUB-CONTRACTOR WHO USES CADDUCT SOFTWARE AND I AM NOT ABLE TO SEE THE DUCT IN 2014 NAVIS IT WAS FINE IN 2013 IS THERE ANY PATCHES OUT THERE TO CORRECT THIS PROMBLEM THANKS
Message 7 of 11
rsloyer
in reply to: rmc1111
ks like I'm having a simlilar issue but with AutoCAD MEP 2014.  Are there enablers for CADduct to MEP 2014?
Message 8 of 11
Nicholas.Hyland
in reply to: rsloyer
Message 9 of 11
jamesbon
in reply to: Nicholas.Hyland
Is there a way to get the Autodesk Fabrication CADmep Object Enabler to function in Design Review or TrueView 2015? And if so, how? Thank you in advance.
Tags (1)
Message 10 of 11
Nicholas.Hyland
in reply to: jamesbon
The Fabrication CADmep 2015 object enabler will need to be installed, I'll post a link once released.
Nicholas Hyland
Message 11 of 11
”Boost
