AutoCAD MEP General
Active Contributor
Message 1 of 11 (6,513 Views)
CadDuct Object Enabler Problem
6513 Views, 10 Replies
02-10-2010 05:13 AM
I have installed MEP 2010 on my computer, and I haven't been able to view drawings drawn with CadDuct. I have installed Autocad Object Enabler and CADmep+ & CADduct Object Enabler on my computer, but I still won't be able to view them. When I opened a CadDuct drawing with my MEP 2010, all I could see was some blocks and texts, not duct work.
Has any of you encountered this problem? If so, what was it you did to resolve this problem?
Thank you,
New Member
Message 2 of 11 (6,512 Views)
Re: CadDuct Object Enabler Problem
02-11-2010 10:22 AM in reply to: TravelTheWorld
I had the same problem so I exported the CadDuct drawing to AutoCAD 2007 format and it worked.
*Mike
Message 3 of 11 (6,513 Views)
02-11-2010 11:53 AM in reply to: TravelTheWorld
I had the same problem in MEP 2009 and when I loaded the mapcadduct.dbx file
manuallly using application load, it worked.
"jasonpark0911" wrote in message news:6333761@discussion.autodesk.com...
Thank you,
Member
aaronkrawchuk1613
Message 4 of 11 (5,095 Views)
05-23-2012 09:38 AM in reply to: TravelTheWorld
Anyone have a 2013 version for this enabler yet.. I am receiving drawings from subs and cannot get their items to show up... AutoCAD says it cannot load the .dbx file...  I am not sure if it is old or not compadible to AutoDesk 2013 versions
Board Manager
Nicholas.Hyland
Message 5 of 11 (4,534 Views)
08-13-2012 06:57 AM in reply to: aaronkrawchuk1613
Here are the details for the CADmep object enablers:
Fabrication CADmep 2013 object enabler (for 2013 products only)
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-fabrication-...
CADmep legacy enabler for AutoCAD 2009-2012 (as *Mike mentions, this version requires manual registration with AutoCAD)
http://knowledge.autodesk.com/support/fabrication-products/downloads/caas/downloads/content/legacy-v...
Hope this helps.
Nick
Nicholas Hyland
New Member
Message 6 of 11 (1,690 Views)
Re: CadDuct Object Enabler Problem 2014
09-12-2013 04:32 AM in reply to: TravelTheWorld
2014 NAVISWORK
UPGRADED FROM AUTOCAD 2013 TO 2014 ALSO THE SAME WITH NAVISWORK AND I ALSO INSTALLED AUTODESK FABRICATION CADMEP 2014 OBJECT ENABLER I  HAVE SUB-CONTRACTOR WHO USES CADDUCT SOFTWARE AND I AM NOT ABLE TO SEE THE DUCT IN 2014 NAVIS IT WAS FINE IN 2013 IS THERE ANY PATCHES OUT THERE TO CORRECT THIS PROMBLEM THANKS
Active Contributor
Message 7 of 11 (1,340 Views)
10-11-2013 12:41 PM in reply to: rmc1111
ks like I'm having a simlilar issue but with AutoCAD MEP 2014.  Are there enablers for CADduct to MEP 2014?
Board Manager
Nicholas.Hyland
Message 8 of 11 (1,244 Views)
10-17-2013 09:19 AM in reply to: rsloyer
New Member
Message 9 of 11 (268 Views)
03-27-2014 10:29 AM in reply to: Nicholas.Hyland
Is there a way to get the Autodesk Fabrication CADmep Object Enabler to function in Design Review or TrueView 2015? And if so, how? Thank you in advance.
Board Manager
Nicholas.Hyland
Message 10 of 11 (248 Views)
03-28-2014 03:51 AM in reply to: jamesbon
The Fabrication CADmep 2015 object enabler will need to be installed, I'll post a link once released.
Nicholas Hyland
You are not logged in.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
