Chris Yanchar has another procedure for saving back to 2000 format which
will maintain the xref's, but the Aec Objects will go back as proxy objects.
1) Create a new profile that has 'Demand load of ObjectARX apps' set to
'Command Invoke'.
2) Create a new program icon that runs with this profile and doesn't have
the ADT template switch or the \ld switch in it.
Now when you launch using this icon, be sure not to run any Aec commands and
you should be able to saveas 2000.
jason
"guggemos"
wrote in message
news:f16a6c8.-1@WebX.maYIadrTaRb...
> When I export to 2000 the xref is bound to the file. Is there a way around
this? I need to keep them separate for future xref background updates.
> Al
