AutoCAD MEP General
Distinguished Contributor
tonyatrsm
Message 11 of 15 (165 Views)
Re: Borrowed License Issues
12-03-2012 08:14 AM in reply to: tonyatrsm
Somewhere all my messages aren't getting to you. I guess you don't get the ones when I reply to your email from my Outlook inbox? The unseccesful ping was just because I thought I was supposed to put the brackets around our server name. After I figured that out I was able to get a succesful ping. Are these files you're asking for on the server itself? Maybe I need to get our IT company talking to you because I am not able to access all files on the server and they are the ones that set up the license in the first place. I tried going to them for help and they gave up and told me uninstall and reinstall the software, which I tried with no luck.
tonyatrsm
Message 12 of 15 (163 Views)
12-03-2012 09:06 AM in reply to: alison.gangler
Alison,
What is the possibility of setting my PC up as the license server? That way we don't have to go thru our IT company every time we have a problem since they are over an hour away and apparently know little more than I do about the license set up. I have missed being able to take the laptop to two meetings in the field now and the only resolution I got from them was to uninstall and reinstall the software, which didn't work. By the way, I noticed on the LICPATH.LIC file in the MEP folder on the laptop C drive the top line had our server name with just a bunch of zeros after it. I looked at an old license file and it had an IP address so I copy/pasted that in the new file and actually got to where MEP opened but got an error that License Manager was installed incorrectly.
Employee
alison.gangler
Message 13 of 15 (160 Views)
12-03-2012 02:23 PM in reply to: tonyatrsm
That would certainly be a possiblity. Please check out the Quick Start Guide for the links to get the Network License Manager:
http://upandready.typepad.com/up_and_ready/2011/11/quick-start-setting-up-a-license-server.html
This guide also has instructions how you can generate the license file for your workstation at www.register.autodesk.com. You will need to have the serial numbers and your HostName and HostID of the workstation.
Here are the install and Configuration instructions as well:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14379546&linkID=9240617
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13503006&linkID=9240697
Please let me know if I can help you further and I will be happy to do so.
Cheers,
Alison
___________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Alison Gangler
IPG - ICP Install Engineer
tonyatrsm
Message 14 of 15 (154 Views)
12-04-2012 04:49 AM in reply to: tonyatrsm
HostName being the name of my PC and HostID being the IP address?
Employee
alison.gangler
Message 15 of 15 (149 Views)
12-04-2012 06:40 AM in reply to: tonyatrsm
The HostName is the Machine Name and the HostID is the physical address or MAC adress. The following solution provides the steps on how you can gather this:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16485462&linkID=9240617
Please let me know if this helps or if I can help you with any other questions.
Cheers,
Alison
Alison Gangler
You are not logged in.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
