Is there a way to terminate an open-ended MEP duct with a bevel cut? i.e., for a section of duct connected to an exhaust fan discharge?
Solved by pothied. Go to Solution.
There is no way to bevel cut a duct. Your only option would be to create an end cap fitting with the desired geometry and place that at the end of the duct.
Hi JCharles2417,
You might look into creating a custom fitting. You supply a path and need just start the DUCTCUSTOMFITTING command. I am not sure if you will be able to get the exact look that you are looking for however.
