I'm using AutoCAD MEP 2010 x64 bit on Windows 7.
I recently had my PC upgraded at work. I have just gone to use the batch plot utility and it doesn't work. I'm trying to plot about 30 DWGs to PDF but when I press Publish the dialogue box closes & nothing happens. It was working fine before the PC upgrade. I was wondering if it is to do with the x64 bit or maybe Windows 7 (I was on Vista before).
A bit of a thread revival. I am now using Acad MEP 2015 on Windows 8.1 x64 and I still have the same problem.
I go to Publish.
Set 'Publish to:' to PDF.
Bring in the drawings I want to print.
Hit the 'Publish' button and the dialog box disappears and nothing else happens.
First steps, are you sure nothing is happening? Could it be a possibility that you are publishing in the background, and PDFs are being sent to you 'Documents' folder by default?
