Show only
Search instead for
Hi Anyav!
The units for airflow is depending on the unit setting in the drawing.
Metric drawings use l/s a unit for flow; Imperial drawings use CFM.
/Bosse
"Anyav" wrote in message news:415aa030$1_3@newsprd01...
do you know if is it possible to change the Units of air flow (BTU) for m3/h ??
if it is posible, how can I do that?
thank you all
Also think about formulas in your property sets. Even if the dwg is in Imperial and you now need the data in metric then a formula based on the cfm could be accomplished.
