AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Autocad MEP 2012 - /p switch doesn't work
4 REPLIES 4
604 Views, 4 Replies
I have made new profiles and saved them out to the hard drive.  Then I changed the /p switch in the target line of the icons to point to the saved profiles but it never reads the profile.
Anyone else experienced this?
B3B
4 REPLIES 4
pendean
Where did you save these files exactly, your post is vague.
Also post a screenshot of your full Target line and popup.
Here is the target line:
"C:\SE_apps\AutoCAD MEP 2012\acad.exe" /ld "C:\SE_apps\AutoCAD MEP 2012\AecBase.dbx" /p "C:\Autodesk Profiles\MEP2012_32 Starter.arg"
It is the same path that I have used for years.
b3b
LanceEdwards13
Is the profile name in options typed EXACTLY as you have it in the /P target?
Lance Edwards
Product Support Technical Specialist
Product Support
Autodesk, Inc.
cut and pasted the path and filename so they are identical.
I'm wondering if maybe there a problem with the profiles so I'm building a new one now.
”Boost
