AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
AutoCAD MEP & Quickpen issue
3 REPLIES 3
eciadam
1665 Views, 3 Replies
I am working with a contractor who is using quickpen 2010 to model plumbing. I am using AutoCAD MEP 2011. When i xref in the plumbing model i have a couple of issues:
1. the plumbing model will not render into a solid. it stays wire frame.
2. i can not snap to the objects of the plumbing model (for instance to ID the elevations). The model seems to come in as proxy object.
One way around the snapping issue is to explode the model before 'xref'ing it into my drawings. however this obviously does not solve the rendering problem. Does anyone have a solution for this?
I've tried to install a couple of quickpen viewers but with no luck.
3 REPLIES 3
joeself
in reply to: eciadam
Do you need object enablers for Quickpen objects?
eciadam
i havent tried any object enablers for quickpen. Do you know where i can find it?
mail
perhaps this link will help in obtaining the proper object enabler for your system.
http://www.quickpen.com/index.php/PD3D™-Viewers/
Fred Edelmaier
FJE Enterprises
www.fjeenterprises.com
”Boost
