AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
AutoCAD MEP 2013 Layer Dialog - Layer pane not updating to selected filters
3 REPLIES 3
Mike_Pluta
1045 Views, 3 Replies
I just recently started having a problem with my layer dialog box in MEP 2013.  If I select a layer filter the layer pane does not update to show those filtered layers - it stays on last selected filter.  Even if I close the dialog box and reopen it still displays the last selected filter.  If I close Autocad and reopen sometimes it will change but then at some point it will freeze up the layer pane again.
3 REPLIES 3
Joshua.Benoist
in reply to: Mike_Pluta
Does it happen with just one drawing or have you experienced it with any file?  Have you tried a repair from the Windows > Add/Remove Programs utility?
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Senior Premium Services Specialist
Global Services
Autodesk, Inc.
Just wanted to follow up.
Joshua
Joshua Benoist, PE
Global Services
Autodesk, Inc.
mpluta69
in reply to: Joshua.Benoist
Joshua,
I have this issue as well and have never found a solution.  I have tried to repair and that did not help.  Do you have any other fixes?
”Boost
