AutoCAD MEP General
Member
Message 1 of 2 (248 Views)
AutoCAD MEP 2012 panel schedule merging cells, multi-pole settings
248 Views, 1 Replies
10-22-2013 09:50 AM
PLEASE HELP!
I am a newbie at MEP 2012 (non-Revit) and I am progressing well. Unfortunately, I have come across what should be an easy fix but I can't figure this one out. That being said...
Using basic OOTB electrical panel schedules, I need the nulti-pole circuits to display as a single row of text, NOT as three rows of duplicate information for each panel slot used. I know the  panel adding dialogue has a option for multi-pole circuits to be shown as a single row (merged), but mine is grayed-out.  Is this part of the table style properties?
At any rate, I need this option to be changed/made available for change. Any thoughts, advice, etc.? Again...
PLEASE HELP!!
THANKS IN ADVANCE!
Active Member
Message 2 of 2 (160 Views)
Re: AutoCAD MEP 2012 panel schedule merging cells, multi-pole settings
11-27-2013 05:03 AM in reply to: soup1967
I was able to do this by changing a multi-pole breaker from 1,3,5 to just 1, 2,4,5 to 2, etc.  It won't save you any time, but it works.
I didn't mix doing this with standard single-pole breakers, so I don't know how it will work.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
