AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
AutoCAD ARCH AND MEP - Cube stops working
4 REPLIES 4
dennis
960 Views, 4 Replies
Odd one here.  Periodically, my view cube stops functioning.  It will still highlight the corners, sides, etc, but when I pick, nothing happens.  All I have found that fixes it is to close and reopen.  Anyone run into this and have a fix?
4 REPLIES 4
klaus.schumann
in reply to: dennis
Hi Dennis,
I assume you have already installed SP1 for MEP (2013 ?) at this stage, but if not try and applying it so see if it improves the situation.
Other viewcube issues can be generated by the display system. At first try turning OFF Hardware accelleration to see if it makes any difference. If you find it does make a difference you may want to troubleshoot each individual HW acceleration component to check which could be causing trouble:
3DCONFIG > Manual Tune > In the "Current Effect Status" list toggle OFF one by one each element until you find the culprit.
You may also want to check if there is a more recent version of your graphics adaptor driver which may work better with AutoCAD and Hardware acceleration ON.
Instead of Restarting AutoCAD every time you have the issue you can also try toggling OFF and then back ON the ViewCube to reset it (NAVVCUBE > ON / OFF).
Hope this helps.
Klaus Schumann
Revit Specialist
kwizats_hadérack
in reply to: dennis
Hi Dennis,
i have the same problem on AutoCAD MEP 2013 from the building design suite.
For me, it's a graphic problem and the only way is to upgrade the driver of your graphic card and manage the 3D config.
The problem for me is that Autodesk don't upgrade the certified graphic cards drivers, as a exemple, mine is a 2011 certified graphic card driver for NVIDIA QUADRO 5010M and at this moment, i have no solution to resolve my problem.
Maybe a day...........................i hope.
A French Autocad MEP CAD MANAGER
Best regards.
Cordialement
Allan
Hi Dennis,
Did you manage to solve the issue with the viewcube?
Klaus Schumann
Revit Specialist
dennis
in reply to: klaus.schumann
I never managed to fix the issue.  However, I have moved on to 2014 and the problem hasn't occured.
”Boost
