AutoCAD MEP General
Message 1 of 9 (590 Views)
AutoCAD 2013 with SP1 Crash printing from Help
590 Views, 8 Replies
04-04-2013 07:34 PM
Our users are accessing the online help on Windows 7 for AutoCAD 2013 MEP with SP1 via the Help menu, when attempting to print found help articles they'e Autocad application is crashing with an error pointing at
AcBrowserHost.exe, see screen print below.
Valued Contributor
kwizats_hadérack
Message 2 of 9 (571 Views)
Re : AutoCAD 2013 with SP1 Crash printing from Help
04-05-2013 02:16 PM in reply to: BRIANWILLIAMS6379
I have the same problem.
A FRENCH CAD MANAGER
Cordialement
Allan
Product Support
Message 3 of 9 (561 Views)
Re: AutoCAD 2013 with SP1 Crash printing from Help
04-08-2013 07:27 AM in reply to: BRIANWILLIAMS6379
The first thing that I would check is to see if you have the latest drivers installed for your printer. If you do not, then install the latest drivers.
If that does not work, you can try downloading the PDF help and see if you can print from there. You can find the AutoCAD MEP help file here: http://exchange.autodesk.com/autocadmep/enu/pdf-documentation
David Pothier
Message 4 of 9 (556 Views)
04-08-2013 07:59 AM in reply to: BRIANWILLIAMS6379
We have the latest print drivers, we've tried multiple printers, we've even tried printing to Adobe PDF and still same error.
We PDF guide you referenced is AutoCAD MEP 2012, the issue is for AutoCAD MEP 2013, we need the 2013 PDF guide if this is going to be the workaround.
Product Support
Message 5 of 9 (553 Views)
04-08-2013 08:06 AM in reply to: BRIANWILLIAMS6379
Sorry about the link to the 2012 help file. Here is the link to the 2013 files:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=18732446&linkID=10809853
David Pothier
Message 6 of 9 (551 Views)
04-08-2013 08:08 AM in reply to: BRIANWILLIAMS6379
Yes, I've tried downloading/installing the offline help, it crashes the same as the web based help.
Product Support
Message 7 of 9 (541 Views)
04-08-2013 10:56 AM in reply to: BRIANWILLIAMS6379
Have you tried printing something else from a web page using the default browser? Perhaps the problem is with the browser or a permissions problem within your network.
Have you tried printing to a different device?
David Pothier
Employee
Message 8 of 9 (522 Views)
04-09-2013 03:04 AM in reply to: BRIANWILLIAMS6379
Would you please send a report when a crash occurred with an email address?
If you did send it, please tell me the email address you sent, then we can investigate it.
My email address is pengfei.tian@autodesk.com
Pengfei
AutoCAD Architecture
New Member
Message 9 of 9 (313 Views)
09-17-2013 11:23 AM in reply to: pothied
Has anyone found a solution to this problem?
I have tried printing to multiple devices, including a pdf, with the same result:  "AutoCAD component has stopped working".  Printing direclty from AutoCAD works fine, so I do not see it as a driver problem.
Cathy
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
