AutoCAD MEP General
Active Contributor
nh0mad
Message 1 of 5 (5,959 Views)
AutoCAD 2011 MEP Express tools
5959 Views, 4 Replies
05-24-2010 10:45 AM
Hi all...
I recently upgraded to MEP 2011. I cannot get express tools to work. I have them pathed to the express folder, and loaded the acetmain.cuix with MENULOAD. I have typed "EXPRESSTOOLS" and "EXPRESSMENU". Both state they have loaded successfully. However, when I try to use any express tools command i get the message "Unknown Command"
Any idea's???
Thanks!
Distinguished Contributor
Mep09Developer
Message 2 of 5 (5,959 Views)
Re: AutoCAD 2011 MEP Express tools
05-25-2010 09:50 AM in reply to: nh0mad
I had to Add/Remove Programs to install it from the disk. Then, I simply went into CUI and added Express to my current workspace menu. I did not have to path any folders or specifically load anything with MENULOAD. It works OK for me. Do you have the folder called Express in your AMEP 2011 folder?
yishu_xu
Message 3 of 5 (5,959 Views)
05-25-2010 09:52 PM in reply to: nh0mad
Hi
If you have load the express tool menu.
I think you have to customize your workspace (command: CUI) to confirm the express tools checked for the ribbon in this workspace.
see the attachment.
Active Contributor
nh0mad
Message 4 of 5 (5,959 Views)
05-26-2010 08:27 AM in reply to: nh0mad
Got it...thanks folks!
Valued Contributor
jedenton
Message 5 of 5 (702 Views)
11-19-2012 10:28 AM in reply to: nh0mad
what if they are not checked?...no check boxes present??
You are not logged in.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
