This is very weird, but we have a project we are working on using AutoCAD MEP 2012. We are laying out a mechanical system with ductwork. The autolayout has been working perfectly and all of a sudden on one of our drawings, it stopped working. When you try to connect one duct to another at a different elevation it just extends the duct to the connector location and does not change elevations or add elbows. The ducts are not connected.
The weird part is..... On another computer you can open a file, start laying out duct and auto layout works perfectly. Now you open the broken drawing and try to do auto layout and it does not work. Then you open the same drawing where everything was working perfectly and BAM auto layout does not work in that drawing either. Now on both computers, auto layout does not work. We did this three times and now auto layout does not work on any of them.
Solved by niranjan_kamath. Go to Solution.
To resolve this issue could you please check and clarify the following:
Check if the above steps helps recovering our file.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
