AutoCAD MEP General
*Expert Elite*
Keith.Brown
Message 1 of 3 (520 Views)
Accepted Solution
Attach a style based property set with a classification filter to a MvPart
520 Views, 2 Replies
02-07-2013 08:16 PM
I have created a new classification list and assigned it to mvparts.  I have created a style based property set and assigned it to mvparts and a specific classification in the list.  I then add a mvpart and assign it to the same classification as the newly created property set.  When i go to attach the style based property to the mvpart it is not available in the list to add.  The only way I can get it to be added is to remove the classification from the property set.
I am doing something wrong?  I want the property set to only apply to mvparts of a certain classification.  This works for object based property definitions but not for style based property sets.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
Product Support
Joshua.Benoist
Message 2 of 3 (498 Views)
Re: Attach a style based property set with a classification filter to a MvPart
02-11-2013 08:59 AM in reply to: Keith.Brown
I think this is as-designed behavior, though yes it appears inconsistent with object based property sets.
We do believe that this would be very helpful to have in the program, and feel that you raise a very good case for enhancing the product.
If you would take the time to go here: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
This is a feedback page where customers can make suggestions. This page is monitored by product managers who affect real change and this request can go a long way in changing the product for the better.
Joshua
Joshua Benoist, PE
Senior Support Specialist
Product Support
Autodesk, Inc.
*Expert Elite*
Keith.Brown
Message 3 of 3 (487 Views)
02-12-2013 09:33 AM in reply to: Joshua.Benoist
Thank you for the reply.  I have made feedback at the appropriate places.
You are not logged in.
Announcements
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
