AutoCAD MEP General
Valued Contributor
milton.fitzgerald
Message 1 of 5 (1,309 Views)
Array & Offset NOT WORKING???
1309 Views, 4 Replies
03-02-2012 08:28 AM
To All,
Has anyone run into the situation where the Array & Offset command are not working at all?
I've tried this on all the "MEP" versions of Acad2011 (I'm running "Global, Imperial, and Metric), and in all 3 cases the array and offset command are NOT WORKING. I even tried the "3D" array and again nothing worked.
Clarification about nothing is working, meaning - the commands go the prompts and then the review does not show your items. Same with offset, meaning the command line ask for you to select your item (line) that you want to offset you select it, give it the measurement, and then the command stops after you pick the side, or hit enter.
Even using offset with just a "Through point" is not working.
BTW, I went to my old machine (32 bit, Xp machine) and the array command was working fine. Of course, this was my original "OEM" version of AutoCAD2011.
As usual, if anyone has any answer that would be great.
Milt (a.k.a. Drafter1981)
Milt Fitzgerald (a.k.a. Drafter1981)
Siemens Industries (Full-Time Office Position)
Fitz’ Digital Cad Service L.L.C. (Consulting Business)
https://sites.google.com/site/fitzdigitalcadservice/
Product Support
Joshua.Benoist
Message 2 of 5 (1,282 Views)
Re: Array & Offset NOT WORKING???
03-13-2012 03:37 PM in reply to: milton.fitzgerald
If you type in CUI at the command line, what CUI is used in the drop down selector for the "Main" CUI file?  Is the Acad.cuix file loaded as a partial CUI?  It has the potential to break the MEP Acad commands.  Have you tried a reinstall with no customizations?  You should consider reposting this to the Core AutoCAD forums where we may get better core AutoCAD suggestions.  This issue does not occur in AutoCAD MEP normally, so it is something unique to your setup.
Joshua Benoist, PE
Senior Support Specialist
Product Support
Product Support
Joshua.Benoist
Message 3 of 5 (1,262 Views)
03-16-2012 02:23 PM in reply to: milton.fitzgerald
Hi, just wanted to follow up.
Joshua Benoist, PE
Product Support
Valued Contributor
milton.fitzgerald
Message 4 of 5 (1,252 Views)
03-19-2012 08:49 PM in reply to: Joshua.Benoist
Josh,
Thanks for writing back. Just let you know there was no resolution to this problem. I believe this was just a "freak thing" with this one drawing. I've deleted the file and started from scratch with no repeat of the problem.
I also had posted this same question on the regular AutoCAD discussion group (under AutoCAD2011),
http://forums.autodesk.com/t5/AutoCAD-2011/Array-amp-Offset-NOT-WORKING-Acad2011/m-p/3354757#M22115
Anyway thanks for trying to help,
Milt
Product Support
Joshua.Benoist
Message 5 of 5 (1,243 Views)
03-20-2012 02:31 PM in reply to: milton.fitzgerald
That sounds like the solution then.  Could have been a corrupt file.  Starting from scratch would then fix it.
Thanks for the update.
Joshua
Joshua Benoist, PE
Product Support
You are not logged in.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
