AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Array Dialog Box Displays No More
6 REPLIES 6
kadmonkee8
9540 Views, 6 Replies
In the AutoCAD MEP 2012 not all Dialog boxes display automatically.
Point style dialog box =ddptype in the command line will display for better coordination
Array Dialog box
are 2 examples of 2 high demand dialog boxes that don't display
is this intentional from Autodesk to remove features that aide in its use?
Is there a fix for this? Please advise.
6 REPLIES 6
bryce.thelin
in reply to: kadmonkee8
Installing Service Pack 1 for AutoCAD MEP 2012 will give you the array dialog window again via the ARRAYCLASSIC command. Here's the link for the update:
http://usa.autodesk.com/getdoc/id=DL17813065
There's also some hotfixes that are good to have:
http://usa.autodesk.com/getdoc/id=DL18022638
http://usa.autodesk.com/getdoc/id=DL18247986
http://usa.autodesk.com/getdoc/id=DL18751298
Let me know if the updates help with the DDPTYPE dialog window too.
Bryce Thelin
AutoCAD Product Support
kadmonkee8
in reply to: bryce.thelin
thank you that fixed the issue
bryce.thelin
Excellent! I'm glad to hear that did it for you.
Bryce Thelin
Does this also work for 2013? To obtain the old style dialog boxes - we are having issue with imputing the angle in the rectangular array.
bryce.thelin
Yes, ARRAYCLASSIC is in AutoCAD 2013. No update is needed to get it into the program like there was with 2012.
Bryce Thelin
shahjalal234
Array dialogue box is no more in Autocad 2013.
”Boost
