I cannot locate AecStructural.apc after installation of AMEP 2012.
Is there any where I can download this file?
It should be in C:\Program Files\Autodesk\AutoCAD MEP 2012\Catalogs\Structural\AecStructural.apc on a 32-bit machine.
Possibly in C:\Program Files(x86)\... on a 64-bit machine.
I'm not sure where you might download otherwise.
You have to do a custom install of AMEP making sure to check the ACA profile for the structural content to be installed.
Steven Micaletti
Design Build Software & Content For AutoCAD MEP
Micaletti is right. Do a custom install. Look for the Content Packs. There will be a heading for Architecture, you want to add a checkmark next to US Imperial, or any others under the "Architecture" heading. Finish install. The structural members will be available in the Style drawings, and from tool palettes.
DO I HAVE DO DO A COMPLETE RE-INSTALL? OR IS THERE A BETTER, EASIER WAY TO DO A CUSTOM INSTALL WITH MEP ALREADY INSTALLED?
go to Control Panel->Uninstall a Program and select Autocad MEP 2012 or your appropriate version. Then click on Uninstall/Change. The setup for Autocad MEP will start and then you should be able to click on ADD FEATURES. Select the architecutral addin and you should be golden. No re-install needed.
Hope this helps.
