How can I can create a takeoff at a 30, 45, or 60 degree angle from a main?
The default seems to continually branch off at 90 degrees and auto format and connects the duct that branches off of main that I want it to.
Terra
what angle is your takeoff built at? Is the connector built at 90 degrees or another angle?
30, 45, or 60 degrees. I have tried to manually change the angle, but it won't let me.
Is your tap a straight tap or is it built at an angle? Some more information about the tap would be helpful. In either case, i do not believe that it is possible to PULL a tap off a main run at an angle. You can however create a tee or a wye with the tap at an angle and then place it and run your duct at an angle but again i do not think you can pull the duct from the main run at an angle. The piping module has this ability but i dont think the duct module does. I could be wrong however.
