Let's try this again...
AutoCAD MEP 2012 has 5 standard bend angles for conduit that it uses when auto-routing a conduit run - 15,30,45,60 & 90 degrees.
Does anyone know where these angles are set at? I would like to add 3 other common bends that aren't listed - 5, 10 & 22.5 degrees.
In AMEP 2010 and farther back one could just add them in the conduit dialog box > Use Routing: Elbow Angle and type in the angle - AMEP would remember the angle for future routing.
In AMEP 2012 if you try and do something similar in the properties window while routing conduit, one can force the angle (by locking it), but it is not remembered.
Thoughts/comments?
Any help is greatly appreciated.
Scott
