I'm working in AutoCAD Building Systems 2007. They recommend that you modify existing parts to create new catalogs. I need to modify the cable tray fittings beyond what is allowed through the catalog or parametric fitting editors and I noticed that they are AEC part definitions which are a single block rather than separate pieces. I want to know if there is a way to edit the block or add to it.
Thank you.
