AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
AEC Details
19 REPLIES 19
Message 1 of 20
345 Views, 19 Replies
AEC Details
Is it possible to install the AEC Details library on ABS3? I get an error message when I
try.
19 REPLIES 19
Message 2 of 20
Hi Joe -
Details should install fine with ABS3. What kind of error messages are you
getting?
jason martin
"Joe Blizzard" wrote in message
news:f12da5a.-1@WebX.maYIadrTaRb...
message when I
> try.
Message 3 of 20
"jason martin" wrote.
> What kind of error messages are you getting?
It says something to the effect of "ADT 2(?!) isn't installed."
Here's a screen shot: http://www.zmm.com/notpublic/error.htm
Message 4 of 20
I get the same message. I had ABS2 installed along with LDT3 (I have all the latest and greatest service packs for LDT3). I uninstalled ABS2 and installed ABS3 successfully (I kept LDT3). However, I am unable to install the Details portion because I don't have ADT2 installed?!? What's the work-around?!?
TIA,
Matt
Message 5 of 20
Hi guys -
I just tried this again, and it still works on my machine (standard
developer excuse).
Are you running the details install from the ABS CD, or the ADT CD. The
installer on the ABS CD has been updated to handle ABS stuff?
jason
"BigCountry" wrote in message
news:f12da5a.2@WebX.maYIadrTaRb...
work-around?!?
> TIA,
> Matt
Message 6 of 20
Trying to install Details from the ABS CD and failing miserably. Help!
~ Matt
Message 7 of 20
Running it from the ABS CD here, also.
Message 8 of 20
Hi Guys -
I'll talk with our installer guru tomorrow and try to post back any
recommendations that he has.
jason
news:2157C0360E422D4A8A83DD31DDCE32A8@in.WebX.maYIadrTaRb...
Message 9 of 20
Thanks, Jason!
Much appreciated!!
~ Matt
"jason martin [Autodesk]" wrote in message
news:EEC7985258E1053EF36B9A38FE50D78A@in.WebX.maYIadrTaRb...
Hi Guys -
jason
Message 10 of 20
Hi Guys -
Just wanted to let you know that we haven't forgotten about you. We've had a
couple of support calls about this as well, and we're trying to track down
the issue.
Sorry for the delay 😞
jason
"Matt W" wrote in message
news:A3AB1A2B560132348E43395FAADE8A6D@in.WebX.maYIadrTaRb...
> Thanks, Jason!
> Much appreciated!!
> ~ Matt
Message 11 of 20
I tested this this morning on my system.
I had no trouble installing and running the AEC Details on ABS3
On a fresh system my install order had been
ADT3.3
Viz4
Arch Studio3
Uninstalled ADT3.3
ABS3
Revit 5
Aec Details 3
All of the above work for me.
Hope that helps someone.
Rob
Microdesk
http://www.microdesk.com
news:246B8E0D088E8875D510D91D00BEA98B@in.WebX.maYIadrTaRb...
> Hi Guys -
a
> the issue.
> jason
> > Thanks, Jason!
> > Much appreciated!!
> > ~ Matt
Message 12 of 20
The machine I'm having trouble with currently has LDD3 loaded and prior to installing ABS
had ADT3.3, ABM2 & ABE2. I just loaded AEC Details on an identical but clean (same
hardware & OS, but no adesk stuff) machine and it worked fine there.
Message 13 of 20
Jason: I sent a Word doc to Rob Finch with the products I had installed from day one.... Here is the list and the order in which they were installed...
1. Installed Land Desktop 3
2. Installed Civil Design 3
3. Installed Land Desktop 3 SP1
4. Installed Civil Design SP1
5. Installed Express Tools
6. Installed ADT33OE.exe
7. Installed Object Enabler Wipeout
8. Installed Road Output Extension
9. Installed Vertical Alignment Extension
10. Installed Point Groups Update
11. Installed ADT 3
12. Installed Mechanical 2
13. Installed Electrical 2
14. Uninstalled Electrical 2
15. Uninstalled Mechanical 2
16. Uninstalled ADT 3
17. Installed ABS3
18. Tried to install AEC Details and installation quits after ADT2 error message.
Hope this helps!
~ Matt
Message 14 of 20
There's apparently something remaining in the registry from the previous versions that's
messing with the installer when some of us try to install details. Anyone have a fix or
workaround yet?
Message 15 of 20
Hello all,
We have had a complication with the installer for AEC Details on Autodesk
Building Systems. I am attaching a zip file which contains the fix for the
AEC Details installer.
To install AEC Details on Autodesk Building Systems 3 perform the following:
1. Copy the Details folder on the Autodesk Building Systems 3 install cd to
a local drive.
2. Download and unzip the attached file into the local Details folder from
above step. When prompted to overwrite the existing file, do so.
3. Run the setup.exe from the local Details folder.
Gerry
Building Industry Division
Americas Support Delivery
Autodesk Professional Services
news:28706392B24D8CA593D25A9199BC6B4C@in.WebX.maYIadrTaRb...
versions that's
have a fix or
> workaround yet?
Message 16 of 20
How can we obtain the fix file other than through this discussion group since your attachment does not show up here if you are using IE to access the group?
Message 17 of 20
Hi Rick -
I've sent a copy of the zip file to the email address you have listed in the
previous post. Please post back if you need it sent somewhere else.
hth
jason martin
"rfeineis" wrote in message
news:f12da5a.14@WebX.maYIadrTaRb...
the group?
Message 18 of 20
Worked like a charm. Will that fix be documented in the knowledge base and made available
online somewhere?
Message 19 of 20
Jason, I'm new to the building System 3 package and would like a copy of the fix in order to install details.
Mike
Message 20 of 20
File sent via email...
"Mavan" wrote in message
news:f12da5a.17@WebX.maYIadrTaRb...
> Thanks
> Mike
”Boost
