Its a fine thing indeed (have on our ADT). The batch update is good but the
export property set data is fantastic.
We are going to make extensive use of it with ADT & would be very useful
with ABS.
Publish of extended data to dwf would be useful also.
Robin Capper
"DdDD" wrote in message
news:6C5A6E3C2BD337526227863573038085@in.WebX.maYIadrTaRb...
> and also base on the fact that as an ABS subscription member it would not
> even let me download it - just view the readme - almost childproof!!!!!
> news:D7ACEAA9256CA74F9BEC489BDF58510A@in.WebX.maYIadrTaRb...
> > Based of the following statement:
> > The Interoperability and Productivity Extension must be installed on
> > Autodesk® Architectural Desktop 2004 with Service Pack 2 and cannot be
> > installed with Autodesk Architectural® Desktop 3.3 or earlier.
> > found in the readme for this extension, as it does not explicitly state
> > ABS2004 can I assume it would be unwise to install this on ABS 2004
> > platform?
> > in particular
> > Batch Update (update sections and elevations in a single step)
> > Object Isolate (isolate selected objects for easier viewing)
> > Export Property Data (export nongraphical information for uses such as
> cost
> > estimation)
> > would be fine things to have....
> > thanks
> > David Driver
