Hi Al -
There is no wall dialog. All of the settings for the wall are now controlled
by the properties palette. If property palette isn't active in your profile,
Press Ctrl-1.
You should probably take a look at the ADT4 UI brain dump by Mark Webb. You
should be able to get a copy at
http://www.stardsign.com/BrainDumps/2004/The%20ADT%202004%20User%20Interface
.pdf (watch for wrapping)
jason
"guggemos"
wrote in message
news:f16a82d.1@WebX.maYIadrTaRb...
> Thanks, Bo, but the next question is when I try to place a wall from the
Design pull down menu the Wall dialog box does not pop-up, only the prompts
on the command line. What's up?
> Al
