AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
ADT Setup
6 REPLIES 6
260 Views, 6 Replies
ADT Setup
How do I set my environment to be only ADT? Do I create a profile with a Desktop Icon which would load the ADT environment?
6 REPLIES 6
Hi Al,
Yes, but you should already have a profile called
Architectural Desktop that you can use. You can copy your ABS 2004 desktop icon
change it. Change the /p argument to "Architectural Desktop", the /t
argument to a template file that you want to use.
/Bosse
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">How
Thanks, Bo, but the next question is when I try to place a wall from the Design pull down menu the Wall dialog box does not pop-up, only the prompts on the command line. What's up?
Al
Hi Al -
There is no wall dialog. All of the settings for the wall are now controlled
by the properties palette. If property palette isn't active in your profile,
Press Ctrl-1.
You should probably take a look at the ADT4 UI brain dump by Mark Webb. You
should be able to get a copy at
http://www.stardsign.com/BrainDumps/2004/The%20ADT%202004%20User%20Interface
.pdf (watch for wrapping)
jason
"guggemos" wrote in message
news:f16a82d.1@WebX.maYIadrTaRb...
> Al
Jason,
Thanks, I checked out the Properties box and I like it. I've downloaded the PDF's and I'll be reading.
Al
Jason, check out this website: www.tinyurl.com
R. Robert Bell, MCSE
www.AcadX.com
"jason martin [Autodesk]" wrote in message
news:B36A531B9A0108FA47667E4A64335EE3@in.WebX.maYIadrTaRb...
| Hi Al -
controlled
profile,
| Press Ctrl-1.
You
| jason
Yea, I know, I'm just lazy 😉
jason
"R. Robert Bell" wrote in message
news:52E4CB1691994C33691E1A97690349D1@in.WebX.maYIadrTaRb...
> www.AcadX.com
”Boost
