Hi All,
Im Happy with Audesk Bldg. Design Suite 2014 great improvement for both Acad MEP and Revit MEP. Thanks to my Boss.
I only have minor queries can anyone help me how to edit some column items of Duct Quantity Schedule from Autocad MEP? I attached snapshot and dwg. test file.
Thanks in advance...
L.Magno
You will be somewhat limited in making the schedule look the way that you want due to the fact that you are trying to schedule different types of things in the same schedule. I can answer a couple of your questions.
You can't edit the value of a cell if the property being used comes from an automatic property or formula. You can always add a text field in the schedule and type the value desired but that can mean a lot of manual typing.
The fittings are showing "undefined" because that is how the fitting is defined. You can easily change it to "Slip Joint" by editing the fitting. See the video here for how to do that:
http://screencast.com/t/MLRePPmtK6o
