Rusty -
Well, the team is just finishing off the last items for the coming release.
They are continuing to read your posts here and have uncovered some issues
in ABS 2006 based on feedback on this forum. I am sure they will be much
more visible once the new release is complete.
At any rate, some of the content in ABS has been deferred. The items that
have made it into ABS 2006 are as follows (from the spec TOC):
1 Table of Contents 2
2 Introduction 3
3 MvParts for Tunis 3
3.1 Direct-Fired Absorption Chiller 3
3.2 Single-Stage Absorption Chiller 6
3.2.1 Units 500-800 7
3.2.2 Units 975-1350 9
3.3 Two-Stage Absorption Chiller 11
3.3.1 380-500 Tons 12
3.3.2 575 to 750 15
3.3.3 850-1150 Tons 18
3.3.4 1200-1650 21
3.4 Air-cooled Chiller 26-130 Tons 25
3.4.1 26-70 Tons 25
3.4.2 75-90 Tons 26
3.4.3 100-130 Tons 27
3.5 Centrifugal Chiller 27
3.6 Air-Cooled Condenser 17-265 MBH Vertical 29
3.7 Air-Cooled Condenser 17-265 Ton Horizontal 29
3.8 Air-cooled Condenser 301-1819 MBH 30
3.9 Evaporative Condenser 30
3.10 Gas-fired cast iron boiler 33
3.11 Modular Gas-Fired Cast-Iron Boiler 35
3.12 Solenoid Valve 37
3.13 Threaded Cap Relief Valve 38
3.14 Enclosed Spring Relief Valve 39
3.15 Y Diaphragm Valve 40
3.16 Weir Type Diaphragm Valve 42
3.17 Lever Balancing Valve 43
3.18 Y Globe Straight Balancing Valve 43
3.18.1 Sizes ½ to 2" 44
3.18.2 Sizes 2.5 to 12" 44
3.19 Y Globe Balancing Valve Elbow 46
3.20 Backflow Valve (Double Check) 48
3.21 Backflow Valve (Double Check), 2 parts: Horizontal and Vertical 49
3.21.1 Sizes 2.5-6" 50
3.21.2 Sizes 8, 10" 51
3.22 Backflow Valve (Vacuum Breaker) 51
3.23 Y Strainer 52
3.24 Exhaust Fume Hood Station 54
3.25 Ductless Bench Fume Hood 55
