Show only
Search instead for
Go ahead and draw your 6" pipe and then grab the pipe grip like you would for a run using a tee. Once you have your pipe run from the tee started, open up the property palette and under Routing Options for branch fitting choose Takeoff Only. This will force the program to use a weldolet instead of a tee.
