AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
msscript.ocx AutoCAD MEP 2012
16 REPLIES 16
Message 1 of 17
kadmonkee8
13795 Views, 16 Replies
I am running Windows 7 x64 with Autodesk product that range from 2010 to 2013 on a subscription 2012 and 2013 AutoCAD mep and 2011,12,13 RME
while trying to modify settings in the Style manager for Duct routing preferences in AutoCAD MEP 2012 I receive an error message.
ERROR; There is a problem with the Script Control (msscript.ocx)
This problem may be corrected by reinstalling Internet Explorer, or by Reregistering the control.
This message appears and I am forced to go to task manager to stop the acad process to clear it out.
I have tried a repair on my computer with no positive results.
I am hoping there is a simple fix but have not seen one on any message boards
please help.
Thank you
16 REPLIES 16
Message 2 of 17
cag5281
in reply to: kadmonkee8
I also have this problem and no solution suggested has worked so far. I have Windows 7, 64bit, and MEP 2011.
Message 3 of 17
kadmonkee8
i was able to correct this by using the info from a previous post. see below
i did follow as written do the first one after this message then go to the next one
i did this in the sequence as shown  part 1 just do step 3 and 4 (in BOLD) after you confirm you can register the control go to Part 2 and follow the instruction as written this fixed my issue
PART 1
02-24-2011 04:48 PM in reply to:MIKE_ST
Here is what I received from AutoDesk Tech support. Which it did not work for us, maybe it will for someone else.
1) The simplest and most common fix is to reboot the computer.
2) The next most common fix is to try a repair, from the Add/Remove Programs > AutoCAD MEP > Change/Edit button > Repair or Reinstall > Repair.
3) The scripting file is actually a Microsoft system file. You can try downloading the Windows Scripting components from (Note: this is for Windows XP customers) http://www.microsoft.com/downloads/details.aspx?FamilyID=c717d943-7e4b-4622-86eb-95a22b832caa&displ....
2) Next thing to try would be a repair installation. Go into Add/Remove Programs or Programs/Features in the Control Panel, find the entry for AutoCAD MEP 2010, click the Change/Remove button, select the option to Repair.  Test to see whether the error persists and the installation repair completes.
3) The 64-bit version of Internet Explorer 7, and IE8, may be preventing it from operating.  Please follow this link to roll Internet Explorer back to IE7 32-bit. http://www.technologyquestions.com/technology/internet-explorer/110486-how-do-i-set-ie7-32-bit-defa....
4) Try reregistering the msscript.ocx file.  Open a command prompt in Windows (from the Start menu, select Run, type in CMD and then enter.) At the command prompt, enter regsvr32.exe msscript.ocx /u and then hit enter. You will receive a dialog box that says “DllUnregister Server in msscript.ocx succeeded.” Click OK. Still in the command prompt, enter regsvr32.exe msscript.ocx and then hit enter. You should receive a dialog box that says “DllRegisterServer in msscript.ocx succeeded.  If it does not say that, it failed to reregister.
5) The AutoCAD MEP 2011 error may be fixed by the above suggestions, though we have one other possibility.  We recently encountered that 2011 error when a user opened a file that contains electrical objects, with the desktop icon that launches AutoCAD MEP 2011 as Classic AutoCAD.  Classic AutoCAD does not have the resource modules needed to draw the electrical objects.  Check your 2011 desktop icon and see if it is launching MEP as classic AutoCAD.  look for a different desktop icon the says AutoCAD MEP US Imperial.
Product Support
Re: MEP 2011 Tool Palettes (msscript.ocx)
04-08-2011 01:46 PM in reply to:jdaulton
Good news.  We have been working on this MSscript.ocx issue.
We recently discovered the cause and developed a solution.   Would you please have a look at folder: C:\Program Files (x86)\Common Files\Autodesk Shared, and verify the existence of the following files.
Aec32BitAppServer.dll
Aec32BitAppServer57.exe
Aec32BitAppServer57.tlb
If missing please find the attached zip file, unzip and copy the above 3 into the above location.   Next, let's import the attached registry settings file.  To import registry, save the txt file attachment to your desktop, rename the txt file's extension to .reg, and then double click on it.  That will fix the registry.  Go ahead and test for the MSscript.ocx error to be gone.   Please let us know your impression on the above material and if this helps.  Have a great day.
Joshua Benoist, PE Senior Support Specialist Product Support Autodesk, Inc.
Tags (1)
Message 4 of 17
fbruno1
I am using autocad mep 2013, I am currently having this issue. I followed the steps above and this hasnt solved the script issue. when I unzip the file I notice the tbl file wont open. i get a message that says to select a program or webservice to open the tbl file. My autocad is completely usless right now and this couldnt have happened at a worse time. HELP!
Message 5 of 17
kadmonkee8
in reply to: fbruno1
AutoCAD MEP 2013 is a new version
not sure if it matters but some solutions wont work in newer versions (but don't hold me to that)
I would uninstall clean up any registry entries relating to that version and reinstall 2013 to possibly clear things up
Message 6 of 17
davestankus
Good Job Joshua!!
Works great!!!
Message 7 of 17
debbie1961
I have tried all of the listed solutions, plus others I have found online. I have this msscript.ocx error on both MEP2012 and 2013. It happened after a Windows update. It was fixed after a restore to a previous point, but unfortunately I forgot to turn off auto update, and the problem came back overnight when the computer updated again. I wasn't able to roll back to an earlier restore point, so I was unable to draw one pipe all day. WHAT is causing this?? I thought it was IE 11, but looking back, I see others have had the problem early than the rolling out of that. Other programs that use visual basic also get this error. Today I will try a CLEAN install of all Autodesk products and see if that helps.
Anyone esle find a solution that works yet?
Message 8 of 17
it helped also on Civil 3D 2014
Message 9 of 17
Thanks! Tried re-registering the msscript.ocx module, but that didn't work. For whatever reason, the Aec32BitAppServer.dll file was missing from the Autodesk Shared folder, although the other two were there. Instead of messing around with reinstalling software, I thought I would go straight for the Aec32BitAppServer.zip download routine. That worked for Civil 3D 2013 when I thought I would have to reinstall everything, so it saved me a huge amount of time!
For information, in case it means anything to anyone, the existing Aec32BitAppServer57.exe was 88KB vs 107KB for the one in the zip file.
Message 10 of 17
AutoCAD-AL
Fixed the problem, I tried everything suggested and nothing worked. I refused to nuke the system. As for the zip files the .dll they talk about does not exist in newer version 2015 at least in the folder described. I down graded my IE from 11 to 8. Then had windows update IE to release 11. This did nothing just use up time. I tried reestablishing contoll and this did nothing.I even copied OCX files from another workstation and that didn't do anything. I loaded all updates and service pakaged for 2015 and removed 360 from my system. I rebooted and tried AutoCAD MEP again and guess what this piping portion of MEP was fixed. What did I do to fix it? Your guess is as good as mine. I'm guessing it was a combination of things that fixed it. Good luck to anyone that has this problem.
Message 11 of 17
MKWeb
The trick is running the registry file AFTER unzipping the files and placing them in the correct folder, registering the msscript.ocx in the sysWOW64 directory (instead of system32) for 64 bit systems and then running the reg file.
Mark 'MKWeb' Hultgren
Message 12 of 17
wpaul32
After attempting all the propsed solutions in this post the only thing that worked for me was to unistall AutoCAD MEP and reinstall. I was getting the error while clicking on a conduit fitting.
Message 13 of 17
RidgewayPlumbing
in reply to: wpaul32
Having the same problem when i tried to install my catalog it works but it still says the error.
Message 14 of 17
karafeeq
Is this solution will work for CIVIL 3D 2016 for the same issue ?
Message 15 of 17
aruf
This solution fixed a similar issue I have been having in Civil 3D 2021.  Thanks!!!
Message 16 of 17
jwilliamsZRQUC
in reply to: aruf
what exactly did you have to do? reinstall CAD? or just make sure a certain script file was in the right folder?
Message 17 of 17
aruf
in reply to: jwilliamsZRQUC
All I needed to do was download "Aec32BitAppServer.zip" file in this thread > Close CAD > Extract the "Aec32BitAppServer.reg "file to my desktop > double-click the "Aec32BitAppServer.reg" file to install > Click Yes to continue > Relaunched CAD and that fixed the error message.
”Boost
