AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
modifying property problem
1 REPLY 1
242 Views, 1 Reply
After I finish drawing a project, I like to move
things to other layers to break it down more.  My problem is, that when I
select certain groups of items, I can't see the layer drop down in the modify
property box.  I can only get it if I break it down by block
reference, Polyline, line etc.  I am unable to change the layer
on "ALL" because it does not give any design data.  Is there a
setting that would allow me to change properties on multiple items?  Hope
this makes sense, it all comes down to a modify properties dialog box
problem.
Mike
1 REPLY 1
Hi, Mike:
Select your objects \ right click, choose Edit
Object Display \ choose Layer \ select a lay you want \ OK.
Hope this helps.
Qi Liang
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
problem.
size=2>Thanks,
Mike
”Boost
