Hi John,
The issue may be that DesignCenter is trying to load on startup. The
attached reg file will delete the DC history key. Cross your fingers, import
the reg file and then launch the product.
Note that the reg file will only work for English ABS3. For other languages
you'll need to browse to the indicated key and delete it.
John, please respond if this works so we can make a tech solution for this.
Rick
"jkemble" wrote in message
news:8EF6BB3C1B19729605293AD146C0672A@in.WebX.maYIadrTaRb...
> Jason
> I believe I was getting schedule tags.
> I have 4 profiles (Hvac,Electrical,Plumbing, and the combined one )
> I reloaded the program files (add and remove in the control panel) and
that
> seemed to fix things still using the same profiles
> This is the second time this has happened where I have had to reload
program
> files from the cd
> Thanks
> John
> "jason martin [Autodesk]" wrote in message
> news:8E70FD9B23E553180FAD33C58512CBEE@in.WebX.maYIadrTaRb...
> > Hi John -
> > The AecDCArch30.arx file is design center. It looks like design center
is
> > crashing for some reason on start up. Since the status of the design
> center
> > window is based on the current profile you "might" be able to basically
> > "delete" your profile and start with a fresh one to keep from having to
> > re-install.
> > Do you by chance remember what you were doing in design center last time
> you
> > opened building systems 3 successfully?
> > jason martin
> > Autodesk
> > news:BEC4F4A4574BBAB3C6529EBB7790C279@in.WebX.maYIadrTaRb...
> > > Program crashes when loading
> > > I had this problem before and had to reload the program to fix it.
Don't
> > > want to reload it every month
> > > One thing I see before it crashes is that it can't load
> "AECDCARCH30.ARX"
> > > Any body have any ideas what I can do short of reloading it again
> > > Thanks
