Ello Lads!
Using AC MEP 2011
Is there anyway to get the wire to break when it goes throuh a device, similar to crossings, without using the break command?
Cheers
/Fredrik
Yes, this is controled by the device style. If you edit the device style, pick on the Design Rules tab, you can control how the wires are trimmed or not trimmed by the device. If you want the wire to stop at the edge of the device, use the Trace Geometry option.
Those´nt that only control it if I connect to the device? In the attachment I show how I want it to behave. Its an issue I try and find a good soloution for consantly =/
