"djarvis" <I
href="mailto:djarvis@acdp.co.uk">djarvis@acdp.co.uk> wrote in message
href="news:f1a433b.0@WebX.maYIadrTaRb">news:f1a433b.0@WebX.maYIadrTaRb...
too couldnt modify the duct sizes but this was due to my duct catalogue being
set to UK sizes. I changed the duct catalogue to US imperial and bingo,
everything was fine. Try checking this in your options settings.
Drew Jarvis,
ACDP.
"djarvis" <Matt,
href="news:f1a433b.2@WebX.maYIadrTaRb">news:f1a433b.2@WebX.maYIadrTaRb...
It may help if you check you have defined the default connection types for
your systems when you initially set up ABS4 as per :
href="http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2863482&linkID=2476435">http:...,
This also fixed the problem with your drawing on my system, It must be in
this area to do with system definitions and catalogues etceteras...
Drew Jarvis,
ACDP, Maidenhead.
"Matt W" <mattw@bvhis.com>
wrote in message
href="news:F01D1F1B858D005541D29932F775C4A9@in.WebX.maYIadrTaRb">news:F01D1F1B858D005541D29932F77......
The connection type for ALL ductwork in our
drawings is Slip Joint (which is what it is set to).
I tried changing it something other than Slip
Joint, clicked OK, then set it BACK to Slip Joint and it still doesn't
work.
Sure would be nice if SOMEONE from Autodesk
would chime in here.
Any other thoughts??
Matt W
There are 3 kinds of people:
Those who can count, and those who can't.
"djarvis" <Matt,
href="http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2863482&linkID=2476435">htt...,
Drew Jarvis,
ACDP,
Maidenhead.
