i would ask if there is a way to become the totale area of surface of an air duct in the voices of computation, for the invoice.
BIM Manager - HVAC and Plumbing designer ___________________________________________________________________________
Please use .Accept as Solution and Give Kudos as appropriate to further enhance these forums.
Solved by tompilzys. Go to Solution.
You can certainly do it but you will need to study the duct fitting in the content builder and come up with the formulas. This is not a feature that is offered with AutoCAD MEP.
Thank for the response. In native revit ducts i can extract the total area, if i import the ducts in revit MEP will the Total area ducts read from Revit?
Revit MEP does not have an import function from AutoCAD MEP to Revit MEP. So im am sorry but what you are asking is just not possible.
@Energytechbz wrote:
the solution is that is not possible in autocad MEP. Only in Revit MEP
Not totally 100 percent true. It is possible in autocad mep. However you will have to develop the formula for each fitting either on the fitting itself using content builder or inside a property set.
Revit is able to do this for you automatically. (I have not verified this myself however)
Yes with duct and elbow is simple, you can resolve with a formula or in excel after the export, but with personalized pieces it's little bit stronger to have the exactly surface.
Because..... this command was unknow for me
i was looking for a solution and nobody help me.
Excelent and easy, thanks you very much.
