AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Spiderwebbing
3 REPLIES 3
adamh
338 Views, 3 Replies
Spiderwebbing
Help, lot's of lines! I opened a drawing this morning, and I'm seeing lines everywhere that cannot be selected. If I switch to realistic view they go away, but since I work for the most part in 2D Wireframe, this is rather annoying. Any help would be appreciated. Thanks! 🙂
3 REPLIES 3
Laks-Autodesk
in reply to: adamh
I can take a look at the drawing file if it's possible for you to upload the drawing file should you still be having this issue.
Lakshminarasimhan Seshadri
Pothman
in reply to: adamh
Try turning OFF hardware acceleration or set LINESMOOTHING (type at the command line) to OFF. One of those items should stop this from happening.
Dave Pothier
adamh
in reply to: adamh
Thanks, I heard back.
I had to turn the LINESMOOTHING off, this cleared up the problem.
Adam Hands
Project Manager Assistant
Robert Lloyd Sheet Metal
Ph 503.838.3863 Ext 5016 | Fx 503.838.3964
Direct 503-606-5016
Cell 503-881-3505
www.rlsm.net |
adamh@rlsm.net
"This message (including any attachments) is intended only for the use of
the individual or entity to which it is addressed and may contain
information that is non-public, proprietary, privileged, confidential, and
exempt from disclosure under applicable law. If you are not the intended
recipient, you are hereby notified that any use, distribution, or copying of
this communication is strictly prohibited. Although steps have been taken to
check for viruses, the recipient(s) should also check to ensure messages are
virus free."
”Boost
