AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Showing hidden center lines in ducts going down
2 REPLIES 2
silviaberian
444 Views, 2 Replies
how can i show the center lines in the duct that goes downwards hidden?  I do have the round part of the duct that is hidden showing that way but the centerlines show as cont. lines.  Does anybody have a solution to this?
Silvia
2 REPLIES 2
johnc1s
in reply to: silviaberian
I believe that is a block. Poke around in the rise and drop styles under HVAC Objects in the Styles manager.
Joshua.Benoist
in reply to: johnc1s
The centerpoint that represents where the center line goes down in a rise-drop block is mapped to a non-plot layer.  It is necessary to be able to select vertical segments in a selection set.  It also is handy if you need to Osnap to the center.  It should not plot unless someone changes the layer inside the rise-drop block itself.
Joshua Benoist, PE
Senior Premium Services Specialist
Global Services
Autodesk, Inc.
”Boost
