This is my experience with export to 2000:
Ductwork drawings will export all right, so will 3d piping. On rare
occasions wit will fail, though.
Electrical drawings loose all homerun labels. Allegedly, the solution shall
be to quick select homerun labels, explode them and then export to 2000. Is
not so easy. In addition to homerun labels, the round-shaped lighting
fixtures will become a point after exporting. These shall be exploded, too,
but then the wiring is not masked anymore by fixtures. In addition, it
becomes quite cumbersome to explode a group, themn examine, then explode
once more...
I've tried to explode entire drawing and it almost was good, except that the
homeruns lost their arrowheads that could be fouind all over the drawing.
Plumbing (schematic) export to 2000 doesn't work either. Everytime I'm
trying, the ABS will close with orange flame. Exploding the drawing causes
that all fittings disappear.
I would appreciate it this matter was addressed ASAP in next service pack or
release.
sp
"Fred" wrote in message
news:7A8E2942F41C5C093E2633BA43039D5F@in.WebX.maYIadrTaRb...
> My questions are regarding saving and saveas to the 2000 and 2004 dwg file
> formats. We run ABS 2004, ABS3 and LT 2002. We are adding seats of Acad
2004
> and LT 2004.
> My understanding is this:
> ABS04 can not saveas, but can be exported to (xrefs bind), 2000. Is this
> correct?
> Acad04 and LT 2004 can saveas 2000. Is this correct?
> If the above is correct, what happens when you open a ABS 2004 dwg with
Acad
> 2004 or LT 2004 and saveas to the 2000 file format.
> The problems are starting to show up with sharing dwgs both in the office
> and when sending to clients. I do not currently have access to Acad
2004/LT
> 2004 to see exactlt what each can or can not do.
> I would appreciate being pointed in a direction that addresses this issue.
> Thank you,
> TEW
