Uh Oh!
Turns out there is a minor problem. Apparently, there is a bug that
requires that the install order of side-by-side ADT/ABS be ADT first, then
ABS. Well, installing the service pack changes the install order to ABS
first.
To fix this - go into the control panel ->Add/Remove Programs -> Autodesk
Building Systems -> Change -> Reinstall or Repair Autodesk Building Systems
2004 and continue the wizard. There is no need to reinstall any of the
applications.
My apologies...
"Peter Terwilliger [Autodesk]"
wrote in
message news:C8F6F15A2E6390CDF756AFC4CE1E074C@in.WebX.maYIadrTaRb...
> Hi Jim -
> No ill effects. We will roll-up both ADT and ACAD service packs when we
> issue our own.
> Everyone - keep those error reports coming in!
> "Jim" wrote in message
> news:740D61204BEC6CBE22BEA4AFAEF9734C@in.WebX.maYIadrTaRb...
> > Peter, Are there any ill effects if I have both ADT2004 & ABS2004 on the
> > same machine, and I install SP1 on my ADT2004?
> > Thanks,
> > -jim
