Hi Slawomir -
See comments inline...
"Slawomir Popiel" wrote in message
news:3475209E496AF42D558C8C90F780175A@in.WebX.maYIadrTaRb...
> My copy just arrived.
> Reviewing the book I've noticed that there is no word on compatibility.
> Please advise on following:
> Can ABS 2004 co-exist with S8/R14?
It isn't officially supported and hasn't been tested, but I can't think of
any reason that it shouldn't work.
> Are drawing created in ABS3 compatible with ABS 2004?
Yes, drawings from ABS3 should work fine in ABS 2004
> Are mv-parts created with ABS 3 compatible with ABS 2004?
Yes, MvParts created with ABS 3 should work fine in ABS 2004
> How to transfer my custom-made automatic object tags to ABS 2004?
You should be able to copy the .dwg files associated with your custom made
tags to the new design center content location and they should work.
> Can I preserve my toolbar setup? Not a big deal, buyt it is a day or two
of
> solid work to get it to my taste.
Probably not easily. When you see the new interface you will see some
significant changes, like the fact that there aren't very many toolbars...
It may be possible to "upgrade" the menu files, but it wouldn't be simple.
> I would appreciate an advice.
> Thanks
> sp
