i have problems with flexible ducts. Attached a video so you can see the problem.
When i connect the duct the program change al the connection...Why?
BIM Manager - HVAC and Plumbing designer ___________________________________________________________________________
Please use .Accept as Solution and Give Kudos as appropriate to further enhance these forums.
Solved by marco.defina. Go to Solution.
OK, it works right only if you design in top view, otherwise the flexile duct don't understand where he must going in the x,y,z.
Yes i tried every escamotage but in 3D view won't work. But no problem i set top view and work fine.
