AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Problems with flexible ducts
3 REPLIES 3
marco.defina
628 Views, 3 Replies
i have problems with flexible ducts. Attached a video so you can see the problem.
When i connect the duct the program change al the connection...Why?
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
3 REPLIES 3
marco.defina
in reply to: marco.defina
OK, it works right only if you design in top view, otherwise the flexile duct don't understand where he must going in the x,y,z.
Keith.Brown
Did you try going from the main duct run to the air terminal?
marco.defina
in reply to: Keith.Brown
Yes i tried every escamotage but in 3D view won't work. But no problem i set top view and work fine.
”Boost
